Known Issues and Observations
Latest version 3.23 of the Configuration Tool
only
- On some Windows PC's configurations particularly where there is
a low amount of RAM (Random Access Memory) and a large Beo5 configuration when
the serialisation and subsequent download starts, the system will hang and the
process has to be ended with Windows Task Manager. This typically happens on PC
systems with RAM of less than 1GB and a download file greater than 1.7 MB
- If you have a SIS USB controller or one with the SIS chip set
included in it, then your PC may not detect your Beo5.
- Sometimes when you put the Beo5 on its charger base and connect
it to the PC, the configuration tool does not detect it unless you switch the
Beo5 off and on again.
- When you send 3rd party RAW codes with delays between them the
Beo5 hangs
- When you assign RC5 protocol commands to hard keys the repeat
function does not work because it does not toggle the 3 bit, but it works from
the screen
- Hidden buttons are not recalculated, so if they are subsequent
unhidden most do not work correctly or not at all
- When submenu keys are copied or moved in the configuration, the
hard keys for this menu are not included
- Missing Radio & CD source options for BeoMaster 5
- After opening a previously saved configuration, some icons are
in different locations on the screen to where they were when the file was
saved.
